Just noticed a bubble
Old May 15, 2003 | 12:21 PM
cobbcustomz's Avatar
cobbcustomz
Default Just noticed a bubble
I just noticed a bubble on the sidewall of my front left tire. How bad is this? Its nothing huge but i am just starting to worry about something like a blow out or whatnot. Is there major reason to be concerned?
Old May 15, 2003 | 12:34 PM
igo4bmx's Avatar
igo4bmx
CockBlockerator
well of course, cuz the rubber in that area has been damaged enough to be stretch from air pressure..
however... i had a small bump (bubble ) in my tire for a hile and no problems.
Old May 15, 2003 | 12:40 PM
Nelson's Avatar
Nelson
Administrator
That happened when you hit a pot hole or something similar, your tire was *pinched* between the rim and the concrete. Eventually that weak spot will burst... it's hazard waiting to happen, can take a few months but it will eventually happen.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old May 15, 2003 | 01:05 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
yeah, i would definitely get that tire replaced soon, because you never know when it could go, and you wouldn't want it to happen when you're on the freeway going 80, lose control, and die, because of something you knew about and could have fixed, but didn't.
Old May 15, 2003 | 01:39 PM
Tirod's Avatar
Tirod
looks like new tires
Old May 15, 2003 | 02:36 PM
randomtask77's Avatar
randomtask77
Wanderer
Do you have Nitto NT-450's? If you do, I'd take a closer look at all of your tires. Even take them off the car and look at the other side as well.
Old May 15, 2003 | 06:56 PM
crucial Si's Avatar
crucial Si
Banned
a bubble is from a broken bead
Old May 15, 2003 | 07:01 PM
cobbcustomz
yea i do.......i had 2 wheels off of my car today and there was no bubbles anywhere on those too. I havent checked the front insides yet but i will take care of that tomorrow.
Grrrr I dont want to get new tires. I had so many other plans
SHould I get 4 new tires or just get a new one to replace this one?
Old May 15, 2003 | 08:19 PM
randomtask77
Wanderer
I'd suggest 4 new tires. Unless you feel that you could get away with just 2 tires for the time being until you could afford to get the other 2 later on. Personally, that would bother me to think that it's only a matter of time before my tires go bad and it might happen at the most inconvenient time. I'd just get it for peace of mind.
Old May 15, 2003 | 08:36 PM
b_dyche's Avatar
b_dyche
owned by a 9 car pile-up
I'd replace the front tires ASAP... losing a rear is no where near as bad as losing a front when at freeway speeds...
I'd then replace the rear tires when your tires are due for rotation (I rotate mine when I change the oil... every 2-3 weeks (2500-3000 miles))...
if you don't put a lot of miles on your car it may be best to do all 4 at once and keep your good tires just in case you have hard times & a problem in the future...
