painting clear taillights to match 99-00,..
Old May 9, 2003 | 12:50 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
Default painting clear taillights to match 99-00,..
im about to do this for a friend of mine but,...i cant remember if im suppose to sand the lens to clean them up or not,...if i do sand the lense what grit should i use,...or is rubbing alcohol gonna clean them up enough for me to paint???,...TIA
Old May 9, 2003 | 01:17 PM
Outxider's Avatar
Outxider
X-Motoring
just clean it up well, no need to sand.
Old May 9, 2003 | 02:17 PM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
Yeah clean with alcohol, let dry.
Spray with a few light coats of Candy Apple Red (or whatever color you are using).
Optional: finish with clearcoat.
I've had two sets of painted tails - one set has been painted for over a year (Spike has them now) without clearcoat and I'm sure the paint is still fine.
My current set has been on for a few months without clearcoat and has held up also.
Old May 9, 2003 | 03:00 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
thanks for the help guys,..one more question though,...i will be putting a couple coats of clear on the tails,...should i just clear the red paint or should i put clear on the whole tail light?
Old May 9, 2003 | 03:06 PM
Cashis EG8's Avatar
Cashis EG8
I would say clear the whole tail so that you don't get that little "ridge" where the red and white meet - and it won't scratch off at that place as easily either.
Old May 9, 2003 | 08:36 PM
onebadassdx's Avatar
onebadassdx
while on the topic of painting tails...i've seen some people with tinted rear taillights...how would one go about doing this?
Old May 9, 2003 | 09:18 PM
str8edgexx's Avatar
str8edgexx
definitely use clear coat, and put it over the whole thing. It will protect it.
Old May 9, 2003 | 10:52 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
go to your local hobby shop and get some RC car spray Tint,...PM Duff Man,...he did this and he knows what the exact name of the paint is i think
Old May 9, 2003 | 11:11 PM
randomtask77's Avatar
randomtask77
Wanderer
Transparent Candy Apple Red by Testors. The # on top of the can is 1605. Should run you about 3 bucks per can. Get two to be on the safe side. Should be available at your local hobby store, or even Wal-Mart.
Old May 10, 2003 | 12:25 AM
Duff Man's Avatar
Duff Man
http://www.testors.com/catalog_item.asp?itemNbr=1414
