View Poll Results: Should i boost my d16 or make a swap
boost
7
35.00%
swap
13
65.00%
Voters: 20. You may not vote on this poll
boost or swap
i would swap then boost but if you wanna boost the d series i say go for it
*hint hint* my buddy has a turbo kit for sale he had on his d16 for 3-5k miles he has for sale pm me if ineterested
Originally posted by Highrpmek
Honda made all there motors NA. So i would stick to that. Do a swap and build all motor. If you have enough money to do a swap and turbo why the hell do you have a CIVIC
Originally posted by SleeperCivicEX
What makes you think building a high compression, high power version of a motor would be any different than putting a turbo on it? They both put stress on a motor that wasn't made for it.
If you build a all-motor, I would do it right.
Engine:
Steel crank, Aluminum rods, Aluminum pistons.
Head:
Titanum valves, Matched spring to the cam, Titanum guides and seats, port and polish
If it is balanced and blue printed properly, this will produce as much power as a turbo without all the troubles. But what do i care, i'm an autocrosser. Grew out of drag racing 7 years ago.
Well, that's what people used to think about the Supra's and running high levels of boost on stock internals. The D16 is very capable of handling un-thought-of boost levels, like up to 16psi on the stock internals. I would definitely get a thicker head gasket, but I know people who run this level of boost and survive just with the head gasket.
ntm that you can buy a greddy kit for like $2k and throw it on in a day to pull 14s that night.
h:With N/A, it's a fine-tuned process that could take years to perfect and a whole lot of green.
I've built and now I'm turboing. mmmmm boost. :drool:
