shaking steering wheel
Old May 7, 2003 | 05:44 PM
Hondaman's Avatar
Hondaman
Black Pearl
It could be a bad tire, if you have a bad cord, you can balance them all you want and it will still vibrate.
Old May 7, 2003 | 06:09 PM
dantastic's Avatar
dantastic
cx power!
ball joints/tie rod ends! checkem i guess...
Old May 7, 2003 | 07:16 PM
huviduc's Avatar
huviduc
tires should be good. i dont think it has anything to do with my rims or tires. it did it with my old rims and my stock steelies
Old May 7, 2003 | 07:33 PM
Hondaman's Avatar
Hondaman
Black Pearl
Heres a little test to see if it's CV joints. This is what the guy at the Honda dealer told me. If you feel the vibrations on the highway, it should only happen under load(ie acceleration). You can also try turning in circles at low speeds in a parking lot. Put one foot on the brake while turning in circles in an open parking lot. Just use the brake to slow the car, not stop it. Now try the other direction. If you feel clicking, or hear it, it's bad CV joints. If you have a tear in your boot, get it replaced ASAP.
Old May 7, 2003 | 08:22 PM
smudge's Avatar
smudge
Originally posted by dantastic
sounds like u may need the hub rings. swap on some stock wheels. if they dont vibrate, u probably need the rings
I agree.
If you have hub rings then it is a high speed balance problem(my porsche did the same thing) and get them re-balanced.I have seen my friend shift the tire on the rim 3 times to get the right balance(each tire has a diff. balance, so some are really hard to get the right weights).
Old May 8, 2003 | 05:15 AM
huviduc's Avatar
huviduc
ill try getting them rebalanced because i can get it free. but i dont think it would be the rings because it did it with my old rims, which had them, my stock wheels, and these wheels. i really dont think it will be the rims or tires whatsoever because it has been doing this since i bought the car. Is there anything with the actually steering that it could be?
Old May 8, 2003 | 05:26 AM
Redcivic's Avatar
Redcivic
One of the original OG's
Duh, if your tires are that worn then that's the problem. Ther are so many things it could be, bent tie rod, broken bead, uneven tires, bad ball joints, bad shocks, etc. but it's not the axles.
Old May 8, 2003 | 06:01 AM
huviduc's Avatar
huviduc
yeah the tires are pretty ****ed in the front, if i take those a throw em in the back, would that maybe fix it. maybe ill try that. i dont have enough to buy more tires, i am getting my swap in less than a month.
Old May 8, 2003 | 07:01 AM
Ochdx's Avatar
Ochdx
how is your camber? if your camber is wacked and your tires are worn on the inside of course you will have shaking problems
Old May 8, 2003 | 02:42 PM
purplx's Avatar
purplx
could be a bad belt in one of your front tires. i had that problem at high speeds. i moved the front tires to the rear and that fixed the problem.
