Car is burning oil... Can anyone tell me the cause?
Old May 7, 2003 | 06:24 AM
doctorsohc's Avatar
doctorsohc
I HATE SCAMMERS!!!!
piston rings for sure! - if it were valve guides or seals u would get smoke only when you start it from cold or after taking off a standing start. N20 is hard on those stock cast honda rings
like the other guys said, check your compression... I'm sure it's gonna be down
Old May 7, 2003 | 06:30 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
well.. with that said, I burn off a little oil too, but when I compression tested, I am at exactly 182 psi for each cylinder - they're all exactly the same.
I'm running 9.5:1 with total seal rings and OEM head gasket. Any idea why I'd be burning off oil?
Old May 7, 2003 | 09:07 AM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
yeah i'm burning some oil with my turbo also but i did a compression test after my near hydrolock last time and it was 195 190 190 190 so i'm not too worried. I also just dynoed 176 whp 173 wheel torque on 8 psi which are pretty healthy numbers so i should be ok
But dumping an extra quart of mobil 1 in every once in a while is getting expensive.
Nitrous is pretty harsh on your motor, i used to spray a 55 dry zex kit like you too and i burned oil back then also, not to mention shooting fireballs out of the exhaust (which destroyed my stock cat)
