Need Opinions
Old Apr 30, 2003 | 09:06 AM
sierrafun's Avatar
sierrafun
Default Need Opinions
Looking into buying a used Civic. since I have never owned one before would like to know if this is a good car, and that this year and engine have a good choice of aftermarket upgrades?
http://www.autotrader.com/findacar/v...or=&cardist=22
Old Apr 30, 2003 | 09:21 AM
Tirod's Avatar
Tirod
looks like a clean car.. and yes there is plenty of aftermarket available, your best bet on the engine is a swap (imo) which is also readily available
Old Apr 30, 2003 | 09:35 AM
sierrafun's Avatar
sierrafun
Well I have a Jeep that takes up much of my budget and time, and a motorcycle, that I am also toying with, so I was not wanting to look for an engine swap, just wanting to build the motor it comes with up as much as possible...
Old Apr 30, 2003 | 09:46 AM
wushu_civic's Avatar
wushu_civic
it would be better if you could do an engine swap but if you want to keep the stock D16 you can work with it. you just won't get as impressive numbers unless you put a lot of money into it. then again if you are just looking for a little extra power it can be done.
Old Apr 30, 2003 | 09:59 AM
sierrafun's Avatar
sierrafun
I just noticed that it said this one was imported from Canada, is that something that is better, or worse? Should I look for an American model?
Old Apr 30, 2003 | 10:28 AM
wushu_civic
the canadian SI is the same as the american EX for the 92-95 coupes and sedans. i think there shouldn't be any major problems that you would have to deal with. then again i'm not sure about all of the differences. i know that there would be daytime running lights but i don't know the details on any other differences between the two.
