OEM Fog Question for 00' Civic Si
Old Apr 27, 2003 | 03:27 PM
Da Grim Reaper's Avatar
Da Grim Reaper
Driftin Master
Default OEM Fog Question for 00' Civic Si
how can i get my fogs to come on without having to turn on my headlights? i heard of people doing this but i dont have a clue as to how they done it... TIA.
Old Apr 27, 2003 | 03:36 PM
Hondaman's Avatar
Hondaman
Black Pearl
Good question, I too look forward to an answer for this.
Old Apr 27, 2003 | 03:44 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
http://www.jdmfan.com
People were having problems burning out the fuse though.
Autocross Help Page
Old Apr 27, 2003 | 03:46 PM
Da Grim Reaper
Driftin Master
thanks do0d but thats either a bad link or a downed site
i cant access it
Old Apr 27, 2003 | 04:37 PM
Hondaman's Avatar
Hondaman
Black Pearl
i cant access it
Yes, the site is down right now. From what I've heard, the guy is having hardware issues and is waiting for parts.
Old Apr 27, 2003 | 05:02 PM
avijiggybear's Avatar
avijiggybear
first you have to take off the panel underneath your steering wheel, then the steering wheel cover. you next locate the wire harness that connects the foglight loom to the end of the headlight stick. u unplug both ends of it. u locate the green/red wire and take it out. there are two little tabs holding it in, u just gotta use a really small screwdriver to push it down and it will come out really easily.
then u locate and take out the wire coming out of the loom from the foglights(it should still be connected to the harness, its the only wire still connected after unplugging both ends). u put the green/red wire where the loom wire was, and vice versa, plug everything back together. be sure to replace the taillight 7.5amp fuse w/a 10amp fuse. ppl have known to burn out the 7.5. after that you're set to go!
Old Apr 27, 2003 | 07:42 PM
CivicSiRacer
i cant access it
BAH! that was a great site. Had lots of info.
Autocross Help Page
