B16A1 Questions
I know i was going to go the route of a B18B, but i stumbled upon a little gold mine. A B16A1, i was wondering (since its a japanese market engine) will it swap in easliy without having to change a bunch of stuff? I ride a 94 civic cx HB. Thanks.
The wiring harness will be backwards and you'll need to buy the hydro to cable clutch conversion kit from Hasport -- like $400. I think it should still more or less just bolt in though.
How much?
How much?
You will also have to modify the distributor. Sport compact car did this swap a year or so ago, maybe I can find the mag. It's a pain IMO. The B16A SIR II is so much better IMO and you can get the mcomplete changeover for around $1,700.00 nowadays. How much are you paying? The biggest expensive will be the mounts and tranny converter from hasport. Just give them a call, they will tell you everything you need, they are really cool. I could'nt have completed my CRX without them and their website:thumbup:
Originally posted by white_n_slow
I have that mag. If you want, I can go look up what all they needed.
Drivetrain mounting parts:
Hasport engine mounts $500 new
Rear engine bracket from teg or delslo from junkyard
OBD1 vtec distributor (teg or delslo)
Drivetrain connection:
G2 teg intermediate shaft and axles
Engine management parts:
OBD1 vtec ecu
hasport wiring kit 1200
Cooling:
Delslo vtec radiator hoses
Other crap:
shift linkages and shifter from teg
obd1 map sensor
teggy throttle cable
high impedance injectors
So you're looking at somewhere in the $1400 dollar range of additional parts, depending on what you can get from the junkyard, and for what price. Also, a number of compatible items might come along with your swap, so it all depends on whats included. Really, the 1st gen b16 swap is best suited to cr-x's and 4th gen civics. It can save you money, or it might not, depending on parts... but even so, at what cost in terms of hassle?
BTW that mag has a 900 hp 4wd carbonfiber golf. Very
Originally posted by bambbrose
If its B16a1 it'll be harder to swap in than a b16a2. Also, if it's JDM, then it should only say B16
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
B16A1's aka B16 first generation are cable transmission. Your 94 uses a hydraulic.
