Vtec controller??
Old Apr 16, 2003 | 06:10 PM
TarHeeL-Si's Avatar
TarHeeL-Si
Default Vtec controller??
I am pretty sure I want to get a vtec controller for my car but I'm not sure what brand or really what i should get. No experience with vtec here so any help would be great. And yes I did do a quick search and found nothing about brands just settings
Thanks,
Kellen
Old Apr 16, 2003 | 10:02 PM
kidd_honda's Avatar
kidd_honda
Get a spoon Vtec coontroller!!!! Its really cool. My friend has it in his D16Z civic. it works only if you get a dyno to set it correctly. It kicks in at 3rd and burns like hell.
Old Apr 16, 2003 | 10:29 PM
DelSolSIinMD's Avatar
DelSolSIinMD
Le Grand Illusion
Default ?!?
At 3rd.... gear?!? Or do you mean 3000rpm? Or what?
:wtf:
Old Apr 17, 2003 | 12:44 AM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
either way, that's pretty messed up. 3k is way too low for vtec to be kicking in.
i personally don't see a need for a controller. honda does a pretty good job of setting the changover point where it should be. unless you've done some major work to your engine, spend your money on something else first.
Old Apr 17, 2003 | 01:05 AM
delsol2001's Avatar
delsol2001
hustlin member
a vtec controller on a D16Z is kind of pointless
Old Apr 17, 2003 | 04:54 AM
ManTiS's Avatar
ManTiS
NinJA
Can you stop spitting out what you hear; what personal experience do you have?
Old Apr 17, 2003 | 06:21 AM
doctorsohc's Avatar
doctorsohc
I HATE SCAMMERS!!!!
word :thumbup: I wouldn't mess with it either. Even with mods you won't gain more than a few horses after countless runs on a dyno. 4500 is the lowest I'd go on Vtec for a D16Z6. Aside from being a tad lean, Honda did a great job on P28s from the factory. Spend your money on something that will make a difference like a ZEX cam.
Old Apr 17, 2003 | 08:48 AM
prelewd2469's Avatar
prelewd2469
Don't go with a vtec controller. Ya you will get those few high end horses. But you loose all your low end and middle range power. I wouldn't recommend it unless you have new more aggressive cam ex. todo. I will most likely make you slower
Old Apr 17, 2003 | 09:28 AM
delsol2001's Avatar
delsol2001
hustlin member
i have a d16 that has: port polish shave head, intake manifold port and polished, angled valve grind, double shot peened rods, micropolished crank, block guard, aem fuel reg, and rail, crower camshft and aem gear, 4-1 header, pretty much built and oh a vtec controller is kind of pointless! vtec doesnt really pull that hard to adjust it sooner anyways:fawk: :joshers:
luti's Avatar
luti
I have the Apex'i V-AFC on my car. I have my VTEC come in at 5,000RPM and go off at 4,000RPM. It actually helps a lot, but I do have a ZEX cam in my car, so the movement of the VTEC crossover and the ability to modify my fuel map for my cam is a big help.
