steering wheel replacement
i am going to be ordering a sparco lap 3 sterring wheel and hub for my car and i was just wondering if there is anything i should know? or need to buy? before i order it. I wanted to get the mugen or spoon, but i cant afford it. so i found the most plain black one i could find. what do you guys think?(plain black, top right)
i dont plan on wrecking anytime soon, and if i do, i might as well go with it, its my life.
and ill still ahve the stock wheel to put back in if i change my mind sometime
cx power!
to take off the stock steering wheel, you need a t-30 torx bit/driver (my air bag was screwed on DAMN tight) and a 19mm socket to get the stock wheel off. you wont need a wheel puller. you probably will want to take ur cluster out and pull the SRS bulb.
i just replaced my wheel with a oem integ leather one
hopefully i can afford a matching leather interior soon
