low idle stalls
The air sensor should be in the air intake tube somewhere between the throttle body and air cleaner.
IAC valve is the Idle Air Control motor. It opens and closes a passage to allow more air into the incoming idle mixture. If it's not functioning or carboned up, the extra air can not get into the mixture allowing the car to idle low and rich.
idle air control valve rite? so its next to the throttle body on the back side....
o2 sensor... and the IAC valve.. what else might cause the car to run rich?.. .mines always running rich. i want to clean them all and maybe my car will run a lil cleaner
