quick notes on removing interior door panel
Old Apr 9, 2003 | 12:59 AM
frank's Avatar
frank
frank from canada
Default quick notes on removing interior door panel
hey like the subject says. is there anything i need to specifically do to remove the inside door panel? anything i should watch out for? where the screws are at? special tools? i just don't wanna screw some clips up or something and i need to rewire a few things (something that wasn't done by me previously) thanks
5th gen sedan (front passenger side)
Old Apr 9, 2003 | 02:49 AM
J'silverHb's Avatar
J'silverHb
its pretty simple overall my window falls off track a couple times a year. i broke a clip so when your taking the panel off just be carefull esp. if you remove the panel alot. all i needed was a screwdriver for the speakers.
Old Apr 10, 2003 | 07:12 AM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
u also need either a hook or the tool to remove the clip that holds on the doot handles. other than that be careful with the clips they are weak.
Old Apr 10, 2003 | 08:03 AM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
Remove screw from tray and take out tray, remove screw from door handle and unhook from behind, remove plastic screw near the upper front of door panel and pull out "black thingy". If you have manual windows, you need the tool to pop the clip out. "Pop" the door panel off one section at a time starting at the bottom. Push door panel upward to "unhook" it from the top of the door frame. Viola!
Old Apr 10, 2003 | 10:26 AM
frank's Avatar
frank
frank from canada
thanks guys you are so helpful
