1998 Honda civic air conditioner blowing hot air..
Old Apr 20, 2010 | 12:14 PM
honda1998civic's Avatar
honda1998civic
Default 1998 Honda civic air conditioner blowing hot air..
1998 Honda civic air conditioner blowing out hot air.. i added a can of straight freon and only last 6 days.. How do you guys feel about leak stops? Ive heard they damage lines lines and cause pluggage... Do you think its worth me giving a leak stop a try? My compressor works fine and would turn off and on like it should when it had freon and it blew cold like it was supposed to but now it sounds dry again underneath my passenger glove compartment like it did when I first noticed it blowing out warm air.. Any idea or things I can look for before I start adding leak stop or shall I just take it in to mechanic? Please post.. thanks
Old Apr 20, 2010 | 12:34 PM
Line7's Avatar
Line7
Platinum Member
Look for the leak first. Its not that hard to find.
Old Apr 20, 2010 | 12:50 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
I'm thinking the lever to switch over cold to hot to cold is broken.
Autocross Help Page
Old Apr 20, 2010 | 03:32 PM
honda1998civic
Its not a lever.. I mean I am running ac on and it blew cold when I had just added freon then it started to slowly die out.. Now looking for a leak do you mean by adding the leak detector with a dye in it? Or do I look for a noticeable busted hose somewhere?
Old Apr 20, 2010 | 07:00 PM
Line7's Avatar
Line7
Platinum Member
Just run your fingers through all the pipes. Freon is easy to detect because its like greasy, green in color, and has a certain smell to it.
Old Apr 20, 2010 | 07:22 PM
honda1998civic
Ok Ill try that.. But I just thought most of the lines where behind firewall so basically impossible to follow that and feel around.. I will try and see how much I can cover though tomorrow.. thanks
Old Apr 20, 2010 | 07:53 PM
8secHonda's Avatar
8secHonda
use the leak detector and a black light it makes the leaks glow ... easier to find a leak with.
Old Apr 21, 2010 | 06:35 AM
honda1998civic
will I have to purge system after useing a leak detector? Or can the residue stay in system?
Old Apr 21, 2010 | 06:39 AM
IanB's Avatar
IanB
MB4
Bump for info, I recharged my system 2 years ago, but this spring I've got no cold air again. I have some learning to do!
Old Apr 23, 2010 | 07:57 PM
honda1998civic
I used leak detector with uv dye but do not see any leaks and still i am losing freon because my ac blows cold but I can tell it is starting to not blow as cold as when I first charged it.. Where can I look that I can not see the leak? I have a 1998 honda civic lx
