difference in proportioning valves???
Old Mar 22, 2003 | 04:03 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
Default difference in proportioning valves???
okay ladies and gents, i know it's been covered a thousand times, but searching isn't doing me any favors...
i'm changing the brake booster/master cylinder/proportioning valve from a weaky DX 96' Civic to a beefy 96GSR.
i've heard a few things about the proportioning valve.....so what gives? do i absolutely have to buy an ITR one or can i use the ABS GSR one that i have? also, i realize that i have to reflare my brake lines which isn't a big deal, but what about actually bending the lines to reach over the other side?
thanks guys/gals!!!! :thumbup:
Old Mar 22, 2003 | 04:09 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
As I believe to the best of my knowledge...the GSR will bolt up. BUT, you need to reflare the lines b/c the GSR uses ABS.
The only time you need to bend the lines is when you are using an ITR MC/Booster.
This is to the best of my knowledge. Im not 100% sure though.
Where did you get the proportioning valve and how readily availible is it? Im looking for the 90-93 Integra or 92-95 proportioning valve for my setup.
Old Mar 22, 2003 | 04:18 PM
SUPER LAUBO
KiMBO's Hubby
thanks bud!!! i knew i could count on you :thumbup:
i ended up buying the setup from a friend of mine, but i'll keep my eyes opened for yah!!!:thumbup:
Old Mar 22, 2003 | 04:22 PM
asiandoood's Avatar
asiandoood
i need it by friday :doh: ...let me know if u can find one cheap like 15-20 bucks h:
im probably gonna go hunting tomowrow.
Old Mar 23, 2003 | 02:15 AM
agent87's Avatar
agent87
Need zzzzz's
Default Re: difference in proportioning valves???
If I'm not mistaken, look for a 40/40 prop valve. Funny that you should say that reflaring the brake lines isn't a big deal since that's what scares most people. There are actually tools for bending lines but I don't know where to get them. I'm sure there are places online though. Good luck.
Old Mar 23, 2003 | 08:57 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
any integra prop valve '90+ will work. You'll need to bend one of the lines that goes into the MC tho. If you look at them, you'll notice both lines come out the same side on the civic one, and opposite sides on the teggy one.
Old Mar 23, 2003 | 10:30 AM
SUPER LAUBO
KiMBO's Hubby
Default Re: Re: difference in proportioning valves???
harbor frieght tools owns big time!!!! double line flaring tools for only $9..>WHOOOHOOO...but i'm kinda confused on how it works...
thanks for all the input..keep it up!!:thumbup:
Old Apr 8, 2003 | 05:28 AM
Gobliins's Avatar
Gobliins
I have a 6 gen too and i have installed a rear disk conversion on.
I have to change the Master Cylinder and Proportioning Valve now.
But not all PV seems to fit on this car...
here a link to a pict showing the PV model on my car...
http://www.hazone.com/images/reardisc/prd021.jpg
and now a link to show the PV found on Teg 94+
http://tech.hybridgarage.com/tech/brakepics/img12.jpg
the desing is very different and i don't know how i can insert my break line in this model of PV...
Can you tell me on wich application i can found a PV who fit on my car please or how i can modify my line to fit on this model ?
Old Apr 8, 2003 | 09:28 AM
white_n_slow
it's my D in a B
That second pic is from hybrid-perf.org. Theyre not saying that only one line will fit in... just that only one of the bolts that holds it to the firewall will fit--which doesn't really matter because there are a bunch of hard brake lines holding it in place. The 94+ teg one works fine.:thumbup:
Old Apr 8, 2003 | 06:54 PM
asiandoood's Avatar
asiandoood
i got mine off a 90-91 integra for my EG. ...it might be a little different for EK civics though.
