Civic 1992+
Old Mar 19, 2003 | 06:15 PM
SnowSerpent's Avatar
SnowSerpent
Default Re: Re: 92-95
Originally posted by kaizix
btw, protege5 is a very nice car.
Thanks for the protege5 love.
I'm thinking of going all show with the Protege5, and want sumthing nice to drive around with.
Old Mar 19, 2003 | 06:17 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
Originally posted by 151 Proof
If you like the 5th gen sedan or coupe then go with one of those. Don't let other peoples opinions sway your decisions. Although I believe the EX's are the only ones with power options, manual windows and locks are a hassle.
though, if you go for quickness, you'll want the lightest version (which would be the one with the least amount of options). i personally would rather have power everything (including moonroof) than be lighter. but that's just me i think.
Old Mar 19, 2003 | 06:28 PM
151 Proof's Avatar
151 Proof
Master of the 151
Unless you have an all out drag car, the weight difference won't make much of a difference on the street. 300lbs on the street is barely anything to nit pick about.
Old Mar 19, 2003 | 06:32 PM
Paulll's Avatar
Paulll
Hail Bent
Default Re: Re: Re: 92-95
If you want something nice, maybe a 5th or 6th gen ex coupe.
Old Mar 19, 2003 | 06:35 PM
flipped cracka
true, but if i raced against a dx in my car, i would probably lose because of the weight. i suppose the slightly bigger engine might make up for it, and it all depends on what he really wants to do with it i guess.
Old Mar 19, 2003 | 10:56 PM
agent87's Avatar
agent87
Need zzzzz's
Default Re: 92-95
Thanks for the replies guys.
I like the 92-95 Civic Sedan and the Coupe. I already have a hatch (Protege5).
From my experience, at least in the SF Bay Area, it seems easier to find used sedans for cheaper and in generally better shape than coupes and especially hatchbacks. Also, I'm pretty happy with mine.
Here's just one link you might want to check out:
https://www.honda-acura.net/forums/s...hreadid=47813&
Oh, and I also really like the Protege5. I'd consider getting one myself if I wasn't so po'.
Old Mar 20, 2003 | 06:56 PM
Nelson's Avatar
Nelson
Administrator
Sedan's BUY MINE
Any of the 3 trims are fine... entirely up to you.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Mar 23, 2003 | 08:31 AM
ExiledinIN's Avatar
ExiledinIN
Any mechanical issues to look out for? In particular, I'm looking for a 92-94 EX Coupe.
Old Mar 23, 2003 | 09:26 AM
151 Proof's Avatar
151 Proof
Master of the 151
There were some cooling issues with the 92's and 93's being charged with a certain refridgerant (I forget the number) but they no longer make it, and if you do find it, it's expensive like $50 a lb (3-4 lbs needed). There were also some probelms with the 92-93's with the distributer failing. Both those problems were corrected in 94.
In all 5th gens though there were some problems with the Oxygen Sensor going bad, it's a $200+ fix through Honda. I'm having that problem myself right now.
Nothing really major to look out for though, a bad O2 sensor isn't going to cause your car to stop working.
Old Mar 23, 2003 | 09:28 AM
Antonio's Avatar
Antonio
Hablo espaņol
get a 5th gen hatch, 5th gen coupe, or a 6th gen coupe
