EK Sedan Questions
Old Mar 20, 2003 | 10:14 AM
synthesis's Avatar
synthesis
Originally posted by avijiggybear
he's wrong about the 99-00 ex having a rear sway, it doesn't come w/it. it has the front however, and it does have the mounting places for the rear, a 99-00 si one will bolt right on as long as u have endlinks/brackets.
do you know if a GSR rear sway fits on a 96-00 civic with the Si end links? i saw a GSR sway for cheap, and i think its 14mm and the Si is 13 mm...
Old Mar 20, 2003 | 10:36 AM
dantastic's Avatar
dantastic
cx power!
on the rear quarter panels different on the 99 sedan? i dont think the outside tail lights are interchangeable.
Old Mar 20, 2003 | 10:37 AM
HondaCar's Avatar
HondaCar
Honda Driver
Get the sedan!!!
Man this guy is always 'thinking' hahahahaha
Old Mar 20, 2003 | 10:51 AM
synthesis's Avatar
synthesis
i'd say if you want to switch all those parts on a 96-98 sedan for 99-00 coupe parts, just get a 99-00 coupe to begin with
whats good are an extra 2 doors anyway?
Old Mar 20, 2003 | 12:11 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
Originally posted by WideBodyEK
if the conversion is anything like the coupe conversion then NO you do not need the rad support
it should be, since they share front ends.
practicallity
plus, it's easier to haul ho's and get into the back seat :naughty:
Old Mar 21, 2003 | 01:26 AM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
yes it can fit on any 96-00 civic, you can even use the gsr endlinks if you want, its just a little tighter if you do.
