bouncy suspension solution
Old Mar 12, 2003 | 04:49 PM
undrgrndhaqer's Avatar
undrgrndhaqer
Mr. EG
Default bouncy suspension solution
I have stock 1992 civic hatch vx suspension with some cheasy R1 coilovers. I've had the coilovers for about a year now and seems to be fine, but ever since I put some 17's on my ride, the ride has been bouncy as hell. I go over a dip, not a hole, but a dip and I can just hear my low pro's rubbing on the fender wells. Solutions to this problem? Within reason of course. I make $170 a week just to give you an insight on spending troubles. Anyone that gives me advise would be much appreciated. Thanks
Old Mar 12, 2003 | 04:58 PM
randomtask77's Avatar
randomtask77
Wanderer
So does it also do the same on your stock wheel and tire setup? You mention that the low pro's are rubbing. Do you mean the tires, or the actual suspension?
My best guess is that you need new shocks for your ride (I don't know if you do have aftermarket shocks, you failed to mention it). www.groupbuycenter.com is a good place to find some aftermarket shocks for your ride.
Although this might not be your problem, it could be a factor. Others might be able to elaborate on your dilemma.
Old Mar 12, 2003 | 05:03 PM
gregz93integra's Avatar
gregz93integra
Banned
is your car slammed or what? how much is it lowered anyways? I would suggest adjusting your coilovers, go 6mm higher at a time.
I had a rubbing problem after I dropped my teg, so I just had to adjust it. this was when I had 16's on.
as for the ride being bouncy, unless you buy $500 coilovers, with new shocks and everything, its gonna be bumpy. stock shocks on aftermarket springs=shocks wearing out and (or) bumpy ride.
good luck adjusting them.
:thumbup:
Old Mar 12, 2003 | 05:38 PM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
Get some KYB AGX's and raise the car up a bit :thumbup:
Old Mar 12, 2003 | 07:50 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
sell the 17's get some 16's, and some good shocks, and you'll have it solved! 17's weren't meant for a civic...
Old Mar 12, 2003 | 08:08 PM
Nelson's Avatar
Nelson
Administrator
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Mar 13, 2003 | 11:06 AM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
:rofl: 17s on an EG :rofl:
tell me you at least have a kit :ugh:
Old Mar 13, 2003 | 12:26 PM
undrgrndhaqer
Mr. EG
I don't have a kit, but trust me they look just fine on my ride. The car is still on the ground with a 3.25" drop. I do have stock shocks with R1 coilovers. Also, the tires are rubbing up inside the fender well of my civic. If you have ever seen a bare civic fender well, there is a strip of metal that runs parallel with the tire. This is a problem because it could cut my tire. If I raise my ride some, the bounce will still be there. I am taking your advise about those kyb agx.... are those just the shocks or are they a whole coilover. Also, is there any other vital components to my suspension that would be WORTH upgrading.... Such as camber kit? Anything to help out the ride... Thanks again
Old Mar 13, 2003 | 12:31 PM
saxtonpaxton's Avatar
saxtonpaxton
crvtec beast
sounds like you could use a camber kit allready if you are sproting a 3.25 inch drop.... it will save the wear of your tires big time!
Old Mar 13, 2003 | 05:41 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Well that's your first problem. YOu are dropped so low that you are prolly bottoming out on your suspension. Prolly didn't notice it as much with smaller wheels and tires since the tires can soak up some of it. But with 17s you don't have much cushion.
Common sense will tell you being that low is not right.
Autocross Help Page
