ecu harness help
Old Mar 7, 2003 | 08:22 PM
etmoron's Avatar
etmoron
Moron Member
Default ecu harness help
going to buy a 94 ls motor soon but was told the engine harness is cut , what harness can i use now ?? any b18a/b ???
Old Mar 7, 2003 | 09:32 PM
dantastic's Avatar
dantastic
cx power!
into what car? if you have a 5th gen, you can reuse the stock civic harness
Old Mar 8, 2003 | 07:45 AM
etmoron's Avatar
etmoron
Moron Member
i have a 5th gen civic si. so basically i can reuse the stock si harness ? but what about all the vtec wires and stuff ? im a big noOb to all this wire stuff.
Old Mar 8, 2003 | 07:49 AM
96extec's Avatar
96extec
The ls engine is not vtec, so you will not use them, you will prob have to ground them so you dont throw a ecu code, good luck
Old Mar 8, 2003 | 08:17 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You just need the LS engine harness. And you can just remove the VTEC and VTEC oil pressure wires from the ECU by taking them out of the back of the ECU plug. Simple.
Old Mar 8, 2003 | 01:56 PM
etmoron's Avatar
etmoron
Moron Member
so basically i can just use the original and and take out the vtec stuff in the harness ?
Old Mar 8, 2003 | 02:45 PM
westcoaststyle
That's what I said.
Old Mar 8, 2003 | 08:56 PM
etmoron's Avatar
etmoron
Moron Member
That's what I said.
thanks alot bro , you saved me some money :thumbup:
