grrr! its clunking!!! help
Old Mar 6, 2003 | 01:39 PM
darkcyde's Avatar
darkcyde
Default grrr! its clunking!!! help
ok so everytime i go over a bump or something in the road, the rear end makes like a clunk noise...like two parts r seperating and then hitting back together. i just had the rear driverside ball bearing replaced. could this just be the new part working itself in? if a better description is needed, lemme know...
Old Mar 6, 2003 | 03:36 PM
Bogatyr's Avatar
Bogatyr
darkcyde,
Uh, ball bearing? Do you mean wheel bearing? Maybe when they re-assembled things, something wasn't torqued down properly. But, wheel bearings don't "work" themselves in. They get lubed and should spin...that's all...no noise.
How about pushing up and down on the bumpers to see if you can isolate where the noise is coming from. It could be something as simple as a muffler coming off a hanger. You could also get the thing on jack stands and see what moves around back there.
Bogatyr
Old Mar 6, 2003 | 04:12 PM
Hondaman's Avatar
Hondaman
Black Pearl
Sounds more like a strut mount or bushing to me.
Old Mar 6, 2003 | 06:38 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
it could be from ur suspensions too. or check the bushings on the rear lca. i believe on some civic there was a recall to replace the bushing. as for me... i get squeeky noise from the trunk and rear side. i heard it also on my friend's teg... it all started after getting stiffer suspension in the rear. do anyone have a cure for that???
Old Mar 7, 2003 | 02:23 AM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
Sounds like an lca bushing to me. I've been a victim to two.
Old Mar 7, 2003 | 05:57 AM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
I think if u lube up the bushing that will make them not squeek.
