SI Syncros??
Old Mar 6, 2003 | 09:55 AM
SpoonGSR's Avatar
SpoonGSR
Default SI Syncros??
My friend is about to buy a 99 Si but the 3rd gear syncro is messed up and it grinds when he puts it is 3rd, does anyone know a site or shop that sells syncros?? How much do you guys this it would cost??
-Thanks
Old Mar 6, 2003 | 09:56 AM
The Beav's Avatar
The Beav
i
it not gonna come cheap, cause the shop has to pull the tranny and take it apart to replace the synchro, i'm saying all things done it's gonna be in the ball park of 2g
Old Mar 6, 2003 | 10:06 AM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
It wouldn't cost that much. To replace them all would be about $1000 thats including labor. The 3/4 synchro will cost about $250 and labor should be about $300-350.
Old Mar 6, 2003 | 10:12 AM
The Beav's Avatar
The Beav
i
to pull the tranny and take it apart alone more than 300-350
Old Mar 6, 2003 | 11:06 AM
4-banging's Avatar
4-banging
Default Re: SI Syncros??
-Thanks
if you have the means and know how to take out your tranny, that'll save you the 300-350. :dunno:
Old Mar 6, 2003 | 12:02 PM
riding low's Avatar
riding low
very interesting numbers...
newb question but: is your gears grinding, the only way to tell if your syncro's are messed up ???
Old Mar 6, 2003 | 02:28 PM
The Beav's Avatar
The Beav
i
if it's in read bad shape you'll have to double-clutch to get into the gear
Old Mar 10, 2003 | 05:17 PM
drew935's Avatar
drew935
Laguna Seca circuit
I rebuilt my tranny myself. It's not hard when you have a Helms book. If you know someone or have a friend at that works at Honda or Acura, they can just order the syncro for just that gear.
Old Mar 10, 2003 | 07:51 PM
The Beav's Avatar
The Beav
i
yeah it would be loads cheaper if you did it yourself
Old Mar 11, 2003 | 08:16 AM
mem00phis's Avatar
mem00phis
mine on my 00 si went the third gear syncro is notoriuos for going bad on alot of b series trannys...i replaced mine myself alot of dealerships make you buy them in the 3rd and 4th set on the main shaft just pull it apart and make sure you only replace what you havta i paid like 150 for the 3rd assembly alone the gear should be okay id look at 5th gears inner sleeve as well while you have the trans open cuz that goes alot too in those cars just see look at the inner ring if the teeth look like they are being grinded to a point replace the sleeve....and DO NOT TAKE IT TO HONDA TO HAVE THEM REPAIR IT! they will charge you 1300 for the service alone dealerships are pricks like that.... just go to a transmission shop they are good on costs
