Suspension Techniques rear swaybar on EK
Old Mar 5, 2003 | 02:45 AM
Brad's Avatar
Brad
wooo nascar!
Originally posted by CPL
I think the shop installed my rear sway bar wrong.
Does anyone have this problem?? The bottom bolt securing the shock to the arm is poking into the bushing of the bar. You think the shop installed it backwords?
yes, you either have to turn the shock around so the nut is facing the front of the car, or somehow remove the nut from the strut fork.. it sucks for me cuz i have kyb agx struts with the adjuster knob on the shock body so now its even more of a pain for me to change my damper..
Old Mar 5, 2003 | 02:46 AM
Brad's Avatar
Brad
wooo nascar!
Originally posted by vizeta
RiceBurninVTEC, your setup looks nice. Did u apply any plates or washers inside the subframe for D-brackets? I'm going to use some washers, do u think it's strong enough?
thanks i didnt apply any extra plates, but you can get a kit from beaks that reinforces it.. its kinda unnecessary for the size bar that ST uses, its more made for the comptech and other larger bars that could more easily tear the subframe. but it couldnt hurt to reinforce it, especially if it will give you peace of mind.
Old Mar 5, 2003 | 11:39 AM
vizeta's Avatar
vizeta
Thx for your advice. but what I'm using is suspension techniques swaybar. i don't think there has any space for mugen reinforement plates in between of subframe and d-bracket.
Originally posted by tokyoracer
if you want it to be stronger... u might want to pick up some mugen reinforement plates... my friend had it on his hatch and after 2 days of hard runs at laguna seca... it was still nice and tight. btw, he got the cusco 22mm rear sway.
Old Mar 5, 2003 | 04:53 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
i believe there is space available cuz otherwise they wouldn't sell it. as for me, i am going to be getting the tanabe front and rear sway bars with the underbody brace and rear lower brace from tanabe. right now, they are in the process of redesigning the sway bars with a new stronger material.. and the price will be cheaper than what it is now. so i can't wait. expected release date is in summer time.
