thermostat
Old Feb 19, 2003 | 03:19 PM
jordan88's Avatar
jordan88
Default thermostat
how often does the thermostat needs to be replaced?
Old Feb 19, 2003 | 03:22 PM
ManTiS's Avatar
ManTiS
NinJA
I'd do it once a year ... but that's me
Old Feb 19, 2003 | 03:38 PM
preylude99's Avatar
preylude99
well it depends, are you having probs with your temperature? sometimes what will actually happen is the thermostat will get stuck open causing your car to run too cold which isnt good.....
Old Feb 19, 2003 | 03:52 PM
jordan88's Avatar
jordan88
cuz honda were checking my coolant hoses and they were still cold after i drove for like an hour. so they recommended me replace the thermostat.
isn't it good for the engine to run cold? what would happen if i dun replace it?
thx
Old Feb 19, 2003 | 07:41 PM
jordan88's Avatar
jordan88
i am just wondering, the hoses that connects the top of the radiator is usually hot, rite? and the one that connects in the bottom is usually cold rite?
so the coolant flows from bottom of the radiator to the engine then out to the top of the radiator, right?
thx
Old Feb 19, 2003 | 08:36 PM
Outxider's Avatar
Outxider
X-Motoring
its usually the other way around. some friends i know, take their thermostat out for good, end results, longer for car to warm up to normal operatin temp, with VTEC motors, it will take awhile before it can activate it, and takes longer for the heater to work.
sometimes a old thermostat will stay close causin ur it not to blow coolant to ur engine, thus ur car will overheat, unless u blast ur heater on full hot.
late
Old Feb 19, 2003 | 10:16 PM
jordan88's Avatar
jordan88
would a head gasket cause problem to the flow, and how can i tell if the gasket is bad?
thx
Old Feb 20, 2003 | 03:53 AM
Tony96EX's Avatar
Tony96EX
A cold running engine will probably idle at higher rpms and consume more gasoline. And in cold weather the heater will not be as efficient.
Old Feb 20, 2003 | 12:35 PM
jordan88's Avatar
jordan88
so how can i tell if the thermostat is bad.
would these be:
coolant level too high, cause by the thermostat no opening or too tight?
coolant hoses are cold?
thx
Old Feb 20, 2003 | 02:09 PM
ManTiS's Avatar
ManTiS
NinJA
Do you overheat?
