newb
Old Feb 19, 2003 | 02:57 PM
Ferio Man's Avatar
Ferio Man
welcome to h-a.net
Old Feb 19, 2003 | 05:03 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Originally posted by upgraded Si
just do a search, there have been ALOT of topics back up since the last crash so it should be easy for you to find stuff, if not just ask...
I couldn't agree more with Crucial on this. You'll spend just as much on bolt-ons that do jack as you will on a Greddy kit or something that will give you 40-80 whp.
All it takes is a little patients and some research. If you blow your motor with a Greddy kit, you're dumb... simple as that. h:
Research a turbo and spend your money there.
BTW, you have a B16A2 in your car, not a B16. It puts out about 160 chp.
Check out www.bseries.net for more info on the B16A2.
Your EX has a D16Y8 with 127 chp. The EX motor is a SOHC VTEC and the Si motor is a DOHC VTEC.
The simple questions forum located here: https://www.honda-acura.net/forums/s...threadid=36017
will help you out a lot as well as the search button
Old Feb 19, 2003 | 05:21 PM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
XBaby: A thicker head gasket will raise your compression ratio. I think your talking about a block gaurd.
Search, read and learn. That's the best thing to do.
Welcome to HAN and know your place n00b :fawk:
Old Feb 19, 2003 | 05:44 PM
westcoaststyle
A thicker gasket will LOWER your cr as it moves the head further from the piston thus creating LESS compression.
A thinner head gasket will raise your compression. h:
Old Feb 19, 2003 | 07:50 PM
The G2 Racer
Want Boost!
Oops......thanks for the correction Josh.
Old Feb 19, 2003 | 08:22 PM
westcoaststyle
np, I gotcher back mang. :thumbup:
Old Feb 19, 2003 | 08:28 PM
Outxider's Avatar
Outxider
X-Motoring
if u do get a turbo kit, dun be like jkan2001 and expect to have 200whp.
get a bolt on turbo kit, you will have a blast with it...try apexi, or greddy, or revhard...
