Thinking of removing heat shields under the car.
Old Feb 6, 2003 | 07:47 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
Default Thinking of removing heat shields under the car.
I'm thinking about removing all the heat shields under the car. My question is:
Any reason not to remove the heatshields bolted under the car other than noise and comfort?
Is there anything I risk by doing so? I don't mind the noise since I'm completely gutted, and the heat I don't think will be a big factor.
I'm thinking of removing all the heat shields under the car. The ones that are by the gas tank, and by the shift linkage. All of 'em.
Project EVA - The Track Package
Project EVA
Old Feb 6, 2003 | 07:54 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
i could have swore i read on this board somewhere that you can start a fire if you park over leaves and shiet like that,...i could have just been really tired though
Snoopy's Avatar
Snoopy
been there done that
i heard of a guy who took the heatshields off from around his cat and he parked in some grass at a car show and the grass caught on fire due to the heat from the cat.
Old Feb 6, 2003 | 08:03 PM
99BlackCivicEX's Avatar
99BlackCivicEX
Doesn't sound like a good idea after hearing the above statements.
Old Feb 7, 2003 | 03:27 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Personally the heat shield (sans the exhaust manifold) weigh all together around 5lbs. That's nothing and not worth the headache and extra heat in the cabin.
Autocross Help Page
Old Feb 7, 2003 | 04:49 AM
huviduc's Avatar
huviduc
i took of my heat sheild because it was rattleing and i dont see how it would make a difference if the heat shild was on or not. the heat shield only caovers the top of everything, keeping heat away from you, therefor if you parked in a field with or with out it, it doesnt make a difference, you could start a fire either way.i have a 5th gen , but my brother has a 6th gen, if i remember correctly, they are only on top too. BUT i do agree, it only ways 5 lbs, doesnt really make a difference.
Old Feb 7, 2003 | 05:00 AM
Redcivic's Avatar
Redcivic
One of the original OG's
Waste of time.
Old Feb 7, 2003 | 06:23 AM
CivicSiRacer
Also protects your hoses and wiring from heat. Want to loose your brakes from your brake lines melting?
Autocross Help Page
