thick head gasket
Old Feb 3, 2003 | 06:15 PM
reddemon009's Avatar
reddemon009
Default thick head gasket
does any one know of a company that makes a thicker head gasket for the 96-00 ex sohc v tec d16 y8. ive been lookin and it seems they only make it for the d16 z6 motor???
Old Feb 3, 2003 | 06:22 PM
Bubb_Rubb's Avatar
Bubb_Rubb
Wooo WOOOO
Isnt that basically the same motor??
Old Feb 3, 2003 | 06:24 PM
reddemon009
ya but supposley there different.. may b the oil ports are different??
Old Feb 3, 2003 | 08:16 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
what would be the purpose of replacing the stock with a thicker head gasket? also.. how do you go about in doing so? do u just remove the valve cover and pop it in or do u have to remove the whole head?
Old Feb 3, 2003 | 08:34 PM
ManTiS's Avatar
ManTiS
NinJA
Lowers compression.
Take off head.
Old Feb 3, 2003 | 09:41 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Originally posted by ManTiS
Lowers compression.
Take off head.
will i be able to remove the head without removing all the valves and cam gears? cuz i don't know how to install the valves back using the feeler technique.
Old Feb 4, 2003 | 05:11 AM
ManTiS's Avatar
ManTiS
NinJA
you have to remove the cam gear along with a bunch of other stuff; timing belt, crank pulley bolt, various hoses, etc
you is confused, do not take off your head
Old Feb 4, 2003 | 06:36 PM
reddemon009
to change a head gasket you have to take the head off. timing belt has to come off the cam gear.and the bracket that goes from the block to the intake manifold. after that take out the head bolts and thats it put on a new gasket with new head bolts and tourqe them down accordingly.
