Advance Timing on d16y8
Leave it stock, or run 14 degrees BTC max. It's marked on the crank pulley. 14 degrees BTC is the mark furthest from the white TDC mark. The mark closest to the TDC mark is 10 degrees BTC. The red mark in between 14 and 10 is 12 degreea BTC. Use a timing light.
I just advanced my D16Y8 last week. It only took 10 minutes. Make surer you have 2 ppl, a timing light, and a paper clip to jump the connector that is in the green boot next to your ECU. I noticed a slight difference, and my gas milage is way better. I used to top out my speed at 106 now it is 111. It wont hurt unless you start hearing a PING!. That means you have detonation so then you have to retard the distributor slightly. Listen mostly for the ping when you test drive it around 1st and 2nd gear. Happy Tuning!
h: i dont top out at all, just goes and goes, no matter where my timing is at. obdII sucl<0rs
when i had my timing at 22 degrees on my z6 when warming up its was at 27 degrees. how come it doesnt ping??
