Power Antenna question for the Amp?
Old Jan 6, 2003 | 07:02 PM
DarkInfluence's Avatar
DarkInfluence
Banned
Default Power Antenna question for the Amp?
I was wanting to know if by doing this would it harm anything cause the Ex Civic has no power antenna and im still using the stock radio. Also what wire behind the dash is the ignition wire that I must find to connect to and if there is a simular wire for the same task then please tell me thanks.
Old Jan 6, 2003 | 10:59 PM
DarkInfluence
Banned
Not a damn person can answer this question of mine?
Old Jan 6, 2003 | 11:02 PM
S2Kev's Avatar
S2Kev
im not sure about what color the remote turn on wire is cuz its a stock headunit but usually on aftermarket headunits, its the blue one.
Old Jan 7, 2003 | 08:13 AM
nando11211's Avatar
nando11211
You will get quicker responses if you post in the Audio & Electronics Forum, try there. Sorry I dont know the answer to your question.
Old Jan 7, 2003 | 07:00 PM
DarkInfluence
Banned
I put in the same question in that same thread and i got no responces at all so there is more activity here then over there.
Old Jan 7, 2003 | 08:22 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
I believe there is already a wire in the trunk for it... I remember someone saying that about a del sol, so I'd assume it would eb the same. If it weren't so bloody cold outside, I'd go check for my own curiosity.
Old Jan 8, 2003 | 06:04 AM
DarkInfluence
Banned
I have a cd change and the wire that goes to the cd changer itself from the radio would be a good wire to use but i would have to split it open. Id rather find somthing in the frot to use. This is goign to be a pain in the ass cause i don't know what to look for.
Old Jan 8, 2003 | 01:18 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
if all else fails, use a live wire with an on/off switch.
Old Jan 8, 2003 | 01:30 PM
19.3secS2K's Avatar
19.3secS2K
lucky for you I have an extra Honda wire harness.
I'm looking at the stock deck (this is an 96-00 deck, btw, but should be universal with all honda's).
There's the main plug in the middle of the unit. There's a total of 12 prongs in it. 4 on the top left, 4 on the top right, 3 on the bottom left, 2 in the bottom middle, and 3 on the bottom right.
the remote power (or power antenna. whatever) is on the top right grouping of prongs, 3rd prong from the left.
now for some ascii grafix :rockon:
imagine you're looking at the back of the deck.
o o o o o R o o
o o o | o o | o o o
see the R? thats the remote antenna connection.
sorry, I wish I had a digi cam
Old Jan 8, 2003 | 05:03 PM
DarkInfluence
Banned
Instead what is better is to use the yellow wire with a red stripe which is the ignition wire. By using that the amp will go on when the ignition is engaged and off when disengaged. The power antena wire oppening has no wire so inorder to use that you would have to buy a connector to fit the hole and go from there. I instead split the ignition and combined it with the remote of the amp.
