Buzzing sound under dash when turn signal on
Hello, has anyone had a problem with a buzzing sound coming from under the dash when you signal? It happened a while back, but stopped for at least 6 months. Now whether it is a left or right signal, the buzz sound comes on, and I believe the signals then don't work. I suspect it is the fuse in the process of burning out. Has anyone had this problem before?
v-card member alpha
I'm no electrician, so maybe it's a fuse issue, but I'd assume it's the relay making the noise... just my first guess.
If you think it's the fuse, just replace it with a new one of the same (or less) rating. It's easy, just look at the diagram on the fuse panel cover. There's a fuse-puller (just makes it easier), or should be, on the fuse panel. It's also listed on the diagram.
