Q for all you that have HELMS
Old Jan 2, 2003 | 01:42 PM
incublinkus's Avatar
incublinkus
JDM Fan Boy
Default Q for all you that have HELMS
I order it a few days ago finally, but I was wondering if somebody could tell me if it has some kind list of tools needed to work on the civic.
I know you need all the sockets and wrenches, timing light, and whatever else, but is there a compiled list of all the different hand tools one would need in HELMS?
thanks guys
Old Jan 2, 2003 | 02:37 PM
DC Sports's Avatar
DC Sports
I have the 1996-2000 Civic Service Manual, and at the beginning of almost every section, there is a Special Tools list, which lists the tools you will need.
Old Jan 2, 2003 | 04:54 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Default What's up?
Aside from the basics, a complete set of metric sockets and deepwells, a set of combination wrenches are useful. A good torque wrench and set of vicegrips are also good.
A few specialty tools, get a flare wrench. Craftsman sells a good one with a 10 and 12mm ends. It looks like a box wrench but has an opening cut out. Great for things like brake lines and such.
If you ever plan to take your axle's out, say for a swap or at least a clutch, you'll need a 32mm socket. The axle nuts are 32 and torqued to 132 ft/lbs. Most 1/2" impact guns don't have the power to break them loose either. A good socket and a strong breaker bar you can take back when it bends usually does the trick. A 8' pole doesn't hurt.
If your pulling the clutch, you'll also need a set of 12-point sockets. The flywheel is held to the crank with them and so is the pressure plate to the flywheel (12 point bolts).
That's all I can think of for now. Air tools are helpful but not nessicary for most jobs. Seeya.
Old Jan 2, 2003 | 05:08 PM
ManTiS's Avatar
ManTiS
NinJA
Default Re: What's up?
Listen to this guy, he knows his $hit. :thumbup:
Old Jan 2, 2003 | 06:05 PM
incublinkus
JDM Fan Boy
:bowdown: :bowdown: :bowdown: :bowdown: :bowdown:
Old Jan 2, 2003 | 06:06 PM
incublinkus
JDM Fan Boy
:bowdown: :bowdown:
Dude, thankyou SO MUCH!
Old Jan 2, 2003 | 06:07 PM
ImportRac3r's Avatar
ImportRac3r
Elite Member
A 10mm and 12mm will almost tear down the whole car.
Old Jan 2, 2003 | 06:46 PM
Andy's Avatar
Andy
Default What's up?
Thanks guys. What ImportRac3r said is really true. A 10mm, 12mm, 17mm and a 19mm for the lugs, and you have a pretty complete toolbox for your car.
Just a few more things. Honda uses pinch clams for hose clamps. It's usually worth it to replace those with your normal hose/worm clamps when you change the hoses. Just makes your life easier (those pinch clamps are a pain). Also, if you pull your rear suspension apart, specifically the 3 bolts on each side that go through your LCA, buy some anitseize and coat the shaft of those bolts before you put them back in. Those bolts have a tendency to rust in the bushing sleeves and will not release. Usually they have to be snapped and drilled out. Seeya.
Old Jan 3, 2003 | 05:39 AM
incublinkus
JDM Fan Boy
Once again man, thank you. I really appreciate the info.
Old Jan 6, 2003 | 08:52 PM
derf's Avatar
derf
Spec5
what does a flare wrench look like?
a helms manual is a must rite?
