refresh my memory...GSR RSB onto 00 ex?
Old Dec 31, 2002 | 08:15 AM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
Default refresh my memory...GSR RSB onto 00 ex?
Is there any drilling required to use a GSR rear sway bar on a 00 ex coupe?
Old Dec 31, 2002 | 08:50 AM
Paul's Avatar
Paul
Eater of Rice
If memory serves me right, Yes.
Old Dec 31, 2002 | 09:55 AM
EX R8ED's Avatar
EX R8ED
is whipped
You'll need the LCA's
Old Dec 31, 2002 | 12:56 PM
madtownhonda's Avatar
madtownhonda
Rear LCAs from integra/5th gen civics do not fit on the 6th gen.
Old Dec 31, 2002 | 02:01 PM
Paul's Avatar
Paul
Eater of Rice
Correct, thus requiring one to drill.
Old Dec 31, 2002 | 02:29 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
oh screw it...i think i'll just get a SI RSB, i believe that bolts in directly
Old Dec 31, 2002 | 03:53 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
All 6th gen Civics have holes in the LCAs to accept swaybar endlinks. If you use the GSR swaybar, the D bracket mounts may not line up with the holes in the chassis, in which case you would need to drill. If they do line up, you will still need to use Si endlinks, since GSR ones bolt up differently. You could use all Si parts, and they'll all bolt up. You would need the bar, bushings, D brackets, bracket mounts, endlinks, and nuts/bolts.
Old Dec 31, 2002 | 04:06 PM
Paul's Avatar
Paul
Eater of Rice
Or he could just buy a swaybar designed for the EX.
