need help idle problem!
Old Oct 19, 2008 | 08:07 PM
daniel9111's Avatar
daniel9111
SiKid
Default need help idle problem!
i just swap my gsr stock intake manifold for a skunk2 manifold but now my engine its idleling... i dont know know what could cause that but i dont want to mess my engine..theres some times when its cold it idles like at 1350Rpm and other times at 1k RPM and when its at normal temp it still idles like at 1500Rpm wat can cause that...
Old Oct 19, 2008 | 09:12 PM
unseen's Avatar
unseen
can u take a pic of the new intake installed how it is now and post it?
did u check all vacum lines tps sensor iacv all plugs are accounted for to correct position and did you put a throttle body gasket on when u put the tb on the new intake? that can cause idle issues and other problems
Old Oct 19, 2008 | 11:29 PM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
I may be wrong, but air in the coolant lines will make the idle surge. Since you swaped the intake mani, and that has coolant lines to/from, air probably got into the system.
Old Oct 20, 2008 | 05:23 AM
unseen's Avatar
unseen
true this can also happen from map sensor sometimes.... just run it with the rad cap off for about 15 mins...
one way to check also for vacum leak is while its running spray starting fluid on the vacum lines and inspect closly it will bog a little if any gets sucked in and u will see the bubbles get sucked in.... u can repair from there
good luck
Old Oct 20, 2008 | 08:05 AM
Omie's Avatar
Omie
ew n!gg@ u g@y
go back to the stock intake manifold. skunk 2 even complains about their i.m. for that motor
