Short Ram
Old Dec 13, 2002 | 07:24 AM
SeeCamGo's Avatar
SeeCamGo
LIGHTS Army Soldier
Josh, how much do you think I could sell my intake for?
Old Dec 13, 2002 | 07:52 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
tree fiddy.
Naw, like $100 prolly.
Old Dec 13, 2002 | 08:39 AM
Nelson's Avatar
Nelson
Administrator
Originally posted by smudge
Most short ram kits are the same.A box would be a great idea.
I thought that too, common sense would assume that also, but I've learned not all are created equal.
There are factors such as: Pipe Diameter, bends, exact materials made, etc... that affect the intake... nothing dramatic, but I guess if you've come down to it, every "little" bit helps.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Dec 13, 2002 | 09:00 AM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
I like my short ram. 3 inch pipe with a Apex'i Filter on it.
Old Dec 13, 2002 | 09:01 AM
westcoaststyle
Ya, I'm thinking about making something out of sheet metal and riveting it all together. I'll prolly make the top out of plexiglass so that I can see it, and open it up so I can replace/clean the filter. Should I insulate it? Prolly so huh? That way the heat from the motor won't heat up the interior of the box. I'm gunna do this thing!
Old Dec 13, 2002 | 09:02 AM
westcoaststyle
Brand?
Old Dec 13, 2002 | 02:22 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Originally posted by westcoaststyle
Brand?
I think he means for you to make your own piping, which would be whatever brand you want to name it. You could use an exhaust mandrel bend.
Old Dec 13, 2002 | 02:25 PM
westcoaststyle
h: Hmm.... not a bad idea.
Where would I get the connecting pieces (like from the intake to the t/b)?
Old Dec 13, 2002 | 09:27 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Aren't you a parts retailer of some sort? I'm sure you could find silicone connectors from one of your distributors. If all else fails, rubber sewage connectors from Home Depot will work.
Old Dec 15, 2002 | 11:16 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Like I said, I considered doing that, but I don't know how I would support the AEM without the correct bracket as a s/r.
See what I'm saying?
dood it's not that hard to keep it mounted. cuz after reading ur post... and since it's been raining like hell here in cali... i started worrying too. cuz last nite on my way home... there was puddle of water... pretty deep and i drove through it slowly but there was still some splash. then i got paranoid... so this morning i woke up hella early to remove the filter... and guess what... water started dripping. it wasn't much but definitely enough to make me really paranoid and motivate me to start hacking away at the pipe.
here is how i did it. on the pipe it should have a sticker AEM. i started hacking it 1 in from the leg of the letter A. after that, i used a 60 grid sand paper to sand around the piping, just so it doesn't cut the filter. then vaccum the inside of the tube and the surrounding side in the engine bay. then use a wet towel to wipe the inside of the pipe... just to make sure u get all the metal crap. then connect the filter. the filter should sit right above a metal tube wrapped with rubber. look at the red circle. here are pics of it.
here is the bottom piping that was cut due to rubbing... and it made a slight cut through the pipe... and that was the culprit for the screaching sound i posted in the engine forum... it seems there was excess air being sucked in from the cut... and made screaching sounds on top of the regular hissing sound.
hope that helped...
