Changed mounts huge vibration
Some Honda engines will torque very little when you quickly crack open the throttle, even with the stock mounts in place. The purpose of what you installed is to reduce that to almost zero, so you shouldn't be noticing any movement - that means the poly mounts are doing their job :hs:
