Weird suspension noises
Old Dec 6, 2002 | 05:56 AM
1999civicEX's Avatar
1999civicEX
9" member
If you did the installation yourself,t hen check all your bolts. If you did not tighten some tight enough they will come loose and the suspension will rock back and forth over bumps and stuff. Mine did the exact same thing.. Then before it got cold, I retightened all the bolts, found several that were loose, and problem solved. Kick ass.
