Whats correct idle speed? 92 civic ex 1.6L
Old Aug 25, 2008 | 10:23 AM
Alfred5279's Avatar
Alfred5279
Default Whats correct idle speed? 92 civic ex 1.6L
Got a stock 92' 4dr civic EX 1.6L (92-95 generation)
Whats the correct idle speed for this car?
some say 700 in general for hondas.
but i find 500-600 on the internet according to this article.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
i need the correct idle to set my timing properly. gotta do a smog.
thanks.
Old Aug 25, 2008 | 03:05 PM
Line7's Avatar
Line7
Platinum Member
between 370-470 rpm. Straight out of the Chilton.
Old Aug 26, 2008 | 07:46 AM
Running925's Avatar
Running925
Your Powder Coater
lol.. please don't put your moter through that abuse!
750rpm Idle is IDEAL
Shoot for 750-800 and it will purr
Old Aug 26, 2008 | 07:50 AM
Line7's Avatar
Line7
Platinum Member
I was surprised when I saw that too. Most D16's range between 550-700 rpm or so, however, particularly the '92 is 370-470 rpm. My '95 d16 idles at 620-720 rpm. Of course, this is all according to the Chilton manual.
Old Aug 26, 2008 | 03:24 PM
fathergoat's Avatar
fathergoat
:3
This man is correct.
Old Aug 27, 2008 | 11:17 PM
Alfred5279's Avatar
Alfred5279
Thanks for all the responses.
yea. the chilton manual may be wrong in my case.
I have a 92' civic. I believe that year, the 4 door model i have is the newer body style. the other 92's have the older body style.
just to clear up the confusion. I have the 93 body style.
2dr, 4dr and hatchback have all the same body style for the 93 model year.
Old Aug 28, 2008 | 06:35 AM
Running925's Avatar
Running925
Your Powder Coater
regardless, they all share the same style motors.
set your idle around 750
Old Aug 29, 2008 | 09:59 PM
A-series's Avatar
A-series
v-card member alpha
It depends if you are setting it, (with EACV disconnected) where it would be lower, or if you are checking it once it's been set.
For that car, full warm idle is supposed to be 650rpm in the U.S. and I believe 750 in Canada (don't ask me why). That's for the 5MT. Auto is 700rpm in U.S. and I believe 750 in Canada. That's what it should have been from the factory.
To set it with the idle screw correctly, you have to disconnect the EACV and then set it to a different, lower, rpm so that when the EACV is connected it will be correct.
If you need to set it, adjusting the idle screw, I could check my service manual for the correct setting (w/ EACV disconnected). Otherwise, best to leave the idle screw alone in most cases.
