OBD-II Help
Old Jun 16, 2008 | 04:15 PM
shsportsfan12's Avatar
shsportsfan12
Default OBD-II Help
Hey guys,
I'm pretty new to Honda's, as I just picked up my 99 Honda Civic DX last night for a daily driver instead of my gas guzzling truck. After getting home with it last night (less than 4 hours after purchasing) the check engine light goes on. It started making some weird noises in the engine bay as well. So today I go pick up an OBD-II scanner to scan for the codes. Well, the scanner (which works because I tested it another vehicle) will not even light up when plugged into the OBD-II port under the dash. I have checked the pins and everything is straight, but my only assumption is the OBD-II port is not working in the car. How can I go about figuring this whole thing out? Is there a fuse specifically for the OBD-II port that I could check. ANY help on this would be greatly appreciated.
-Mike
Old Jun 16, 2008 | 11:07 PM
shsportsfan12
Never mind about this. I seemed to find the problem. The interior light fuse was blown, which in turn was also tied in with the OBD-II port. After it was replaced, I was able to scan the computer.
Old Jun 17, 2008 | 12:56 PM
remy's Avatar
remy
im pretty sure you will never forget that...after fixing your own problem...it stays with you for the rest of your life...now thats knowlege!
Old Jun 18, 2008 | 06:37 PM
thetunersource's Avatar
thetunersource
good items im glad it got fixed
