Turn signal bulb question
Old Nov 10, 2002 | 05:39 AM
DarkInfluence's Avatar
DarkInfluence
Banned
Default Turn signal bulb question
Is there some sort of bulb or LED buld that regularly when on is white and when you want to use it as the turn signal it blinks orange? What I see by APC is a led light that has little lights all clear but, flash red when used.
http://www.eautoworks.com/html/ORD-1-1-1-5080.cfm
What I wanted to know if there is a simular bulb that would do the same except white/orange all in 1 bulb.
Old Nov 10, 2002 | 06:57 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
http://www.jegs.com/cgi-bin/ncommerc...61&prmenbr=361
They have some amber ones on that page.
I used LEDs in my tails for a long while and they just don't light up well in the daytime. They have just a dot instead of a broad light. I don't recommend them, but hey, it's your car.
Old Nov 10, 2002 | 07:57 AM
DarkInfluence
Banned
Just wondering about these. The specs say that it glows red or amber depending on the light that you buy but, is it just red or just amber and thats it without red and amber togerther? Im basicly looking for 1 bulb that can do both colors. 1 to shine white normally and when I make a turn it blinks amber. Im also refering to the front signal lights.
Old Nov 10, 2002 | 08:12 AM
pinoydon2003's Avatar
pinoydon2003
i'm almost 100% sure that there's no such bulb that you're talking about.. the APC LED's ur talking about are clear when off, but colored when turned on/blinking.. however, ur idea sounds pretty to me
Old Nov 10, 2002 | 03:30 PM
DarkInfluence
Banned
Honestly to me instead of me drilling in an extra hold in the headlight box just to add an amber bulb to turn on only when i use the turn signal, I would rather have 1 bulb do both. The LED bulb looks like a great way to do it with its potential yet there is none like you said that can shine 2 colors. Damn it all.
Old Nov 10, 2002 | 11:02 PM
VTEC's Avatar
VTEC
Most plug and play LEDs have WORSE illumination than stock. But if you want to buy my 1156 amber and 1157 amber LEDs, let me know. =)
Old Nov 11, 2002 | 12:12 AM
airon's Avatar
airon
AARONNOJIMA.COM
i would imagine in a dual filament bulb this would be very expensive as you would actually ahve to different bulbs in one essaentially
Old Nov 11, 2002 | 03:40 AM
DarkInfluence
Banned
Maybee expencive but, worth it in a way since my current situation is that in using clear signal lights now instead of amber. If the APC LED which flashes red is regularly clear then whats not to say that you can have the center part flash amber and the outer flash clear. I dont even use the signal lights, i only have them on to shine clear at night to match the headlights.
My only other route is to connect a small amber bulb in the box of the headlight that can be shown when flashed this way I can stay clear from all legalities.
Honestly I'm not into the orange with white look. I can dissconect the "always on" portion of the signal light wire but, it would then look as thoguh part of the light is burnt out. It's all about preferance.
Old Nov 11, 2002 | 04:22 AM
westcoaststyle
Seems like you're going through a lot of hassle for something so insignificant.
Old Nov 11, 2002 | 05:51 AM
oc_civic's Avatar
oc_civic
mcc racing
audi has them.. and i read a LONG time ago in some silly magazine.. that the company that makes is gonna make them for ricers.. ehh i mean honda enthusiasts.. it was NOT an led... i have no idea how it worked but if i can find the magazine.. which i probably can.. i will post the info
