Rubbing question?
True. I had to roll my fenders because over here, the roads have tendency to have hidden dip, and bumps all over. When I dip, I rub. Driving back and forth on the parkway is like a war game for me... I have to remember where dips and bumps are.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
When you say rolling the fender upwards does that mean that after i take off that plastic pieace that I should bend the plastic the rubber is laying on Upwards basicly folding it to touch the fender itself and then i should reconnect the rubber back onto it? What i am questioning here is why should i reconnect the rubber if thats the correct process?
cx power!
for the rear: http://integra.vtec.net/wheels/rollfender.html
for the front: bend the metal tabs (up) that the plastic screws attach to along the edge. some ppl remove the plastic splash shield altogether, but there's wiring there what i dont want to risk.
Dantastic that site worked GREAT. I had 500 pounds in the car (Parents) so I could test to see if it would rub at all. It only rubbed 1 time and thats because I made a sharp turn. Anyway the fender s just a quarter of an inch covering the tire making it look very sporty and I have perfect camber all around thanks to the front camber kit and the washer trick in the back. Thanks people.
I would suggest buying a set of wheels that are 16x7" with 42-44mm offset if you can and sell your current rims. Cutting the fenders is/can be bad later and you will prolly regret doing it
Autocross Help Page
Autocross Help Page
