camber fix
Old Apr 11, 2008 | 06:09 AM
oa80948's Avatar
oa80948
Default camber fix
hi, i have a 97 civic ex coupe and the rear camber is (i think) is -2 just on the left side, i was doing so research about it and saw on some forum that people use washers to fix it. so my question is do it work? because i don't want to spend $140 on one side.
http://home.earthlink.net/~civicex95/rearcamber.html
thank you
Old Apr 11, 2008 | 11:05 AM
HECTIC_1's Avatar
HECTIC_1
I would think that if you were to go with washers they would eventually ware out and you would have the same prob. I would have them fixed with the camber kit.
Old Apr 11, 2008 | 11:21 AM
Line7's Avatar
Line7
Platinum Member
Unless you have a very dramatic drop, a 4-wheel alignment will adjust your camber.
Old Apr 11, 2008 | 12:00 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
-2 degrees of camber is nothing to worry about. Get the toe aligned and you'll be just fine.
Old Apr 11, 2008 | 01:35 PM
oa80948's Avatar
oa80948
thx for the reply, well my car is only drop 1", i tried to get it aligned and the guy at the shop said i need a camber kit on the left side.
Old Apr 11, 2008 | 04:07 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Stop giving out wrong information. Honda Civics are not camber adjustable from factory you have to purchase a camber kit in order to adjust camber. You can only adjust toe on Honda Civics.
Also if you are dropped no more than 2" your camber should be fine. What wears out tires is bad toe-in or toe-out. Get that set to 0 and you should be ok. Just rotate your tires every 3000-5000 miles.
Autocross Help Page
Old Apr 11, 2008 | 07:36 PM
HECTIC_1's Avatar
HECTIC_1
So if I have a 2" drop then what do I need to do to set at 0
Old Apr 12, 2008 | 01:38 AM
CivicSiRacer
Set toe to 0 front and back.
Autocross Help Page
Old Apr 12, 2008 | 08:19 PM
Line7's Avatar
Line7
Platinum Member
Sorry, didnt know that. My shop told me that they'll adjust my camber when I was getting an alignment.
Old Apr 12, 2008 | 11:05 PM
oa80948's Avatar
oa80948
how to you adjust the toe? do they adjust it when they adjust the alignment?
