turn signal
before disassembling anything....
CHECK the bulb first before anything. as already said the bulb is a DUAL filament. one of the filaments could be the culprit. it could be as simple as that.
Originally posted by 96extec
Replace the signal relay,i think it is under the hood or dash,try switching the relays to see it anything changes,i would put my money on the relay
Always start with the most basic, simplest solution first (change the bulb), then if that doesn't work, then look into more complicated solutions. No sense in changing relays and sh1t if you just had a burnt out filiament in your bulb.
I just encountered the same EXACT problem. I just went outside to take a look, turns out that when I tapped into my front corner for my aftermarket side-marker, the cold weather caused the electrical tape to harden and eventually fall off, the exposed wiring was being grounded to the chassis... hope this definitely solves your similar issue!
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
in most hondas when your signals go hyper-super speed, it means one of the filaments is burned out
