head gasket change
Old Mar 22, 2008 | 12:50 PM
gliaZeD's Avatar
gliaZeD
Default head gasket change
i have a 92 honda civic and i need to change the head gasket and valve cover gasket! can anyone help! with details and possibly pictures!
ANY HELP VERY MUCH APPRECIATED
thank you
Old Mar 22, 2008 | 01:19 PM
m735is's Avatar
m735is
I use the Haynes manual when I do mine.
I'm sure there's a write up somewhere on here, try the search.
Hondahookup MAY have a pdf manual also.
Old Mar 22, 2008 | 01:33 PM
waynet's Avatar
waynet
Hi all I think that I can help I was a Honda Tech in the 80's first of all I would break the crank bolt free after that was free the rest is down hill take off the dome cover take off the distributer and bring #1 to top dead center take of the front upper shroud two ten's take off the bottom shroud that will give you access to the timing belt and the water pump and that now you can start undoing the valve train move the rockers out of the way now you are down to the dead bolts start in the middle of the head and in a clock wise rotation undo the bolts out to the edge take all the bolts out tap the head with a plastic hammer until it's lose clean the deck of the block send the head out to be magna-fluxed and planed and start putting it back together in the reverse order
