b16 to b18
Old Oct 16, 2002 | 08:40 AM
4-banging's Avatar
4-banging
Default b16 to b18
advantages/ disadvantages (if any) of swapping the block of a b16A2 (00 Si) to a b18c1
would this be costly, below $1200??
what extra parts would be needed (connecting rods, etc) and I would like to keep my a/c and pwr steering.
Old Oct 16, 2002 | 09:08 AM
96extec's Avatar
96extec
Now do you want to put a b16 head on a b18 block..? i am pretty sure that the head and block will bolt up fine. you will have more compression when you do that,because the b18 has a bigger piston,it will give you more h.p not sure how much but i should work
Old Oct 16, 2002 | 09:16 AM
crucial Si's Avatar
crucial Si
Banned
it give you more torque. it will match up fine..b series to b series. i belive this can be done way under $1200 just depends on how you go about it and buying the parts if you want to upgrade the internals. while your at it, might aswell change your timing belt and water pump and other misc shiit so it wont be needed till far into the feature.
Old Oct 16, 2002 | 09:56 AM
Watertick's Avatar
Watertick
i started a post similar to this like a week ago.....
https://www.honda-acura.net/forums/s...threadid=27547
hopefully that'll help answer your question
Old Oct 16, 2002 | 04:44 PM
sunshine's Avatar
sunshine
Torqueless Wonder
If memory serves me well, the b18c block with a b16 head = poorman's ITR
Old Oct 16, 2002 | 05:27 PM
crucial Si's Avatar
crucial Si
Banned
h: oh man......a b-series motor w/ swap w/ anyother b-series motor..ie, b16head w/ b18b,b18c1,b18c5(which has a b16 head)b20 block and you can use any tranny you want from a b series also.
Old Oct 16, 2002 | 07:20 PM
Tirod's Avatar
Tirod
b18c5 (type r) is basically a b16a2 head and b18c1(gsr?) block....
Old Oct 16, 2002 | 09:32 PM
Outxider's Avatar
Outxider
X-Motoring
yep poorman's itr. late
Old Oct 17, 2002 | 08:29 AM
4-banging's Avatar
4-banging
yes..
wow, thats good news
just to get it on the road and running, would a new timing belt and water pump suffice?
later on down the road internals will be needed but what and I suppose from the gsr block?
what about the ecu?
Old Oct 17, 2002 | 09:44 AM
crucial Si's Avatar
crucial Si
Banned
Originally posted by 4-banging
yes..
what about the ecu?
1...since your engine will be pulled out you might aswell do it...no harn in it.
2...from internals...they would be gs-r internals..unlesss you stoke it out.
3....you can use your current ecu w/ no problem. if you have a buddy w/ a gsr that is obd2(96 and up)try running it with his and she if it runs better.
