replacing the stock steering wheel
Old 11-20-2007, 06:03 PM
alllooksnnogo
Just another import lover
alllooksnnogo's Avatar
Default replacing the stock steering wheel
I want to replace the stock steering wheel in my 98 civic. I have a p28 obd1 chipped ecu installed. Don't know if they are even working. If the stock steering wheel is removed will the air bag deploy? Will I throw a code?
Thanks guys!
Old 11-20-2007, 06:10 PM
Civic2Scooby
Civic2Scooby's Avatar
no they won't blow, the airbags are run by a seperate module from the ECU so yes they are still working...annnnd no you will not throw a code if you replace the wheel with another OEM wheel such as the S2000 wheel. If you install an aftermarket wheel with no provisions for airbag than yes the SRS light will come on.
Old 11-20-2007, 07:11 PM
Zabouskie
Zabouskie's Avatar
Ok This whole thing has got me going about an S2000 wheel, something i've always wanted to do. Do you know if they bolt up directly to a 2000 civic's colum? And the airbags are 100% compatible? I didn't know that, can you tell me more?
Old 11-20-2007, 07:22 PM
Civic2Scooby
yes the S2K wheel will bolt to the spline, and the airbags will work.
Old 11-20-2007, 07:29 PM
Zabouskie
Zabouskie's Avatar
so its litterally a plug and play? does that apply to all years of the s2000 wheel or only certain years?
Old 11-20-2007, 07:31 PM
Civic2Scooby
I know AP1 work, and somebody on here said the AP2 wheel will work also, but I can't for sure say the AP2 will work.
Old 11-20-2007, 07:55 PM
3lo
3lo's Avatar
if you install aftermarket wheel, you can put in a resistor for srs to be off.
Old 11-20-2007, 10:01 PM
Zabouskie
Zabouskie's Avatar
What years are AP1 and AP2? I might be able to get a hold of a 2001 S2000 wheel, is 2001 AP1? or did they make both versions through the S2000 years?
Old 11-21-2007, 02:59 AM
alllooksnnogo
What resistance would the resistor need to be?
Old 11-21-2007, 11:00 AM
Zabouskie
Zabouskie's Avatar
oh great look what i've caused, its best the resistor be forgotten about, just pull the SRS light bulb if you dont wanna see a light.
