frame bent?
Old Oct 19, 2007 | 12:29 PM
1 quick sol's Avatar
1 quick sol
try rotateing your tires or drive on different roads and c if that makes a difference.
Old Oct 21, 2007 | 09:47 PM
mtrivera's Avatar
mtrivera
they send if it is bent it wont be perfect and i also got a new set of tires with the alignment
Old Oct 31, 2007 | 08:29 PM
shapeenero's Avatar
shapeenero
frames do not bend easily and the frame is unibody sooo their are like alot of smaller sheet metalpieces welded and glued together if you want to know if its bent just measure from the rear fender bolt on the right side to the front fender bolt on the left and then you get the distance write it down and then go do it opposite like left rear to right front should be same number as right to left trust me your frame is probally fine ive pulled many honda frames replaced front aprons and countless rad supports frames rarely bend and if they do you can tell it looks off and then you measure
