Need some info on a ZC SOHC VTEC
so i dropped a zc sohc vtec in my 97 hatch.....i know i know its an older engine but oh well...i just wanted 2 know if anyone knew anything about these engines or had some specs
And my last question is the tranny is leaking! not much but its still leaking and i was wondering if anyone could give me some advice or suggestions and what i can do 2 try and fix the leak!???already searched and found nothing
thanks in advance for any help
If it's an auto, I would suggest you keep checking the level to make sure it doesn't get too low.
If manual, you can check it from under the car but if it's a good size leak I would park it until you get it fixed.
Just in case you're considering it, do not add any transmission leak-fix products to a Honda, especially not an auto. You'll save money in the long run by getting it fixed properly.
