B18B smoking.
Old Oct 8, 2007 | 03:52 PM
TotalVelocity's Avatar
TotalVelocity
Is it really worth it to LS/Vtec or should i turbo it?? That is once i fix it. I need to get the ac going b/c i do live in florida.
Old Oct 8, 2007 | 05:41 PM
raiden571's Avatar
raiden571
turning u inside out
its a waste of money for the type r stuff. plus who cares if the shocks and springs are off a type r. a set ok tokico shocks and custom spring rates will do fine and be adjustable. upgrade your rear sway bar too.
id turbo it first. if you have never driven a car that is faster than what you have now, a simple turbo kit will make you very happy
Old Oct 10, 2007 | 03:25 PM
TotalVelocity
Cylinder number 4 170. Cylinder number 3 178. Cylinder numbers 1&2 180. Piston rings are still good. Cylinder leak down test showed no signs of valves leaking so the seals are the problem. WOOOT
Old Oct 13, 2007 | 03:10 PM
TotalVelocity
would havent an LS comp help me any instead of my stock comp ?
