Valve Cover Gasket
Old Aug 2, 2007 | 08:02 PM
Running925's Avatar
Running925
Your Powder Coater
Originally Posted by Omniscient
copper spray do a few coats on the whole gasket and let it sit till its tacky, unless its a paper gasket, then i dont think you do that.
void this comment.. copper spray is for head gaskets.. not valve cover gaskets.
Old Aug 2, 2007 | 08:38 PM
Civic2Scooby's Avatar
Civic2Scooby
I use hondabond on the corners and cam cap areas even with a new valve gasket. Just for good measure.
for some reason I have found honda bond works better than regular RTV black...I mite be placebo'ing, but I even use hondabond on my subaru h:
Old Aug 2, 2007 | 08:43 PM
Omniscient's Avatar
Omniscient
warm butter on toast
h:
Originally Posted by Ra005e
Cool, this doesn't apply to me now and may not ever, but should you also use hondabond on the corners of a head gasket?
Old Aug 5, 2007 | 10:50 AM
ricehnda94's Avatar
ricehnda94
Mcgyver
Just reuse the gasket untill it becomes hard and non rubber like. If you are going to use a gasket sealer stay away from the silicone stuff as that stuff is not safe for sensors and can clog stuff if you use to much. If you are going to use gasket sealer of any brand use it sparingly.
Old Aug 6, 2007 | 09:51 PM
the 96 civic oh's Avatar
the 96 civic oh
he is right use it sparingly
