94 civic SRS light
94 civic SRS light
My SRS light is now on since I changed the fuse.. I'm pretty sure there is nothing wrong with it.. I just was stupid and pulled the fuse out and changed it to be safe,, now it won't go off.. I tryed taking the battery off for like 2 hours. It did nothing other people must have had this problem..?
my 2 cense
i tried the same procedure on my 96 odyssey. It worked but the lite came back on a few weeks later. I tried the steps to reset again and now the final 2 blinks which indicate 'clear' doesnt happen.
You are probably going to have to take it to a dealer and have the code pulled. Some things are covered under warranty for example any seat belt or buckle is covered and the opds unit is covered. More than likely it the opds unit i have seen several fail.
Maybe ur SRS is actually broken? It could be.. try changeing the fuse and then trying it again.. when I did mine.. i did it really fast i didn't count or n e thing.. when the light came on i riped it out.. and when it went off i put it in really fast i didn't wait or give it a sec... cuz the first time it didn't work.. cuz i took to long.. GL
