Need assistance change fuel filter 94 civic ex coupe
Hi I need to change my fuel filter.. i don't think its ever been changed it's a 94 civic ex has 350k miles runs good.. just started to get a little weird on start up.. anyone know a good site to help me do it myself. Thanks..
Also My speedometer kicks on and off, I would think it's somthing loose,, anyone know where that little loose wire is i can tap? THanks for all the help.
Car specs
****94 Civic Coupe EX****
D16 (single cam)
Manual transmission.
Car specs
D16 (single cam)
I recently changed my fuel filter. Start up issues might have something to do with your mail relay, too. Remember to loosen the bolts on the top of the filter before you loosen it from the firewall. And get a rag to surround the sides, because a little gas is going to spill out.
The black round thing on the left. Remove the top bolt on the far left and the the one the line facing the firewall. Then loosen it fro the base. Reverse your steps for install. Make sure you put a rag around the base to collect the gas that's going to spill out. It won't spill for long. Your new filter should come with the washers. I'd use them and discard your old ones. They're tiny and thin so you might wanna be careful with them.
I changed the fuel filter.. very easy...
Thanks for everyone's help.. have a good one
