94 civic cv change Q
Old Jul 11, 2007 | 10:09 AM
mason rocket's Avatar
mason rocket
my 2 cense
Default 94 civic cv change Q
What is the reason behind draining the transmission fluid when changing out the half shaft? I changed a half shaft on a van without draining the fluid and it went just fine. Anybody know if it is absolutely nesessary to drain the tranny fluid i.e. will there be problems down the road after the axle change if the fluid isnt drained for the change out?
Old Jul 11, 2007 | 10:46 AM
Civic2Scooby's Avatar
Civic2Scooby
uhh..I have never drained the tranny fluid to change a CV....nor have I ever heard anybody say to.
Old Jul 11, 2007 | 11:37 AM
mason rocket
my 2 cense
Default manual says it
I have a crappy haynes manual that says you should do it. I did one on an odyssey not too long ago and that manual said also to drain the fluid for the change. It wasnt a haynes manual but something else. I didnt do it because I didnt see the point. just wanted to know from someone else who agrees.
Old Jul 11, 2007 | 12:12 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
I wouldn't do it. I drained the fluid from my 5-speed, and had to pump the clutch about 500 times to get the air our of the lines. Pain in the butt.
Old Jul 11, 2007 | 01:47 PM
Civic2Scooby
that doesn't even make sense....
Old Jul 11, 2007 | 02:51 PM
qtiger's Avatar
qtiger
There's no real reason for the fluid change other than it's convenient and you'll likely leak some when you pull the half shafts.
Just as a side note, aftermarket axles for civics are so cheap ($40 a side) that I'd probably just throw a new axle on rather than replace the joints.
Old Jul 11, 2007 | 03:10 PM
mason rocket
my 2 cense
I found that out pretty quick. Cheaper to get one at a parts store new then bother ebaying or junkyarding it. As far as draining the tranny goes, I've drained and refilled my manual tranny oil at least once on 3 different hondas I bought and didnt have any problems with air in the system.
Old Jul 11, 2007 | 03:50 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
Sorry about that. Wrong part.
:hs:
